Author Topic: Had a leak around the thermostat housing  (Read 1378 times)
« on: July 13, 2011, 05:27:10 PM »
  So I replaced the Upper Hose(it was old) could not tell if it was the housing so pulled that and replace the thermostat while I was there.   Got it all back together and was running it to see if I fixed the problem.
  Nope Heater hose(Which only has a few miles on it) Has a Pin hole almost missed it its that small.  Was not even leaking enough to have missing fluid.  Just enough of a leak to have a wet thermostat housing every once in a while. :brick:  This is the good insulated red hose.
