Author Topic: injectors... in a TJ. what's the lastest story?  (Read 6329 times)
Offline MarkyB
Re: injectors... in a TJ. what's the lastest story?
« Reply #15 on: August 17, 2011, 09:42:57 AM »
Found a used set (not cleaned) on ebay for $60 shipped.
« Reply #16 on: August 17, 2011, 10:38:54 PM »
I don't know.
I'm just posting info as I run across it. ;)
ah, ok - i misunderstood what you meant by "tidbit"
Offline MarkyB
« Reply #17 on: September 10, 2011, 03:05:41 PM »
I ordered a used set on eBay for $50 shipped.
We'll see what they do.
Any suggestions for cleaning them before I put them in?
Also, I couldn't find a step by step writeup on swapping injectors.
« Last Edit: September 10, 2011, 03:34:59 PM by MarkyB »
« Reply #18 on: September 10, 2011, 04:06:18 PM »
not hard just be patient with them
« Reply #19 on: September 10, 2011, 05:10:50 PM »
i think Jeffy has a writeup, if not in the faq somewhere on this site.
Offline MarkyB
« Reply #20 on: September 10, 2011, 08:08:40 PM »
Found it!
In the FAQ section "Chrysler/Jeep and FoMoCo Fuel Injectors"
Offline MarkyB
« Reply #21 on: September 19, 2011, 05:53:14 PM »
Ok I put the injectors in the Jeep today.
The stock ones did not have the plastic caps on the ends. I was concerned about the different sizes, but a quick check with the calipers showed them to be a perfect fit.
Offline MarkyB
« Reply #22 on: September 19, 2011, 06:12:10 PM »
Ok, So the Jeep fired right up.  Right away I could tell it runs smoother.  On the test drive, the throttle response was better, and so was the power.
I'm very happy with the results.
