Author Topic: rear brake flex line  (Read 1637 times)
« on: September 18, 2011, 08:18:16 PM »
i need a suggestion for the rear brake flex line that goes from the frame to the axle, need one for a 4.5'' lift that has the splitter at the end, i cant' reuse the one i had as it's too short
what are you using?
thanks in advance for all suggestions.
Re: rear brake flex line
« Reply #1 on: September 18, 2011, 08:57:55 PM »
found one at 4wd for $42, any cheaper options that you might know would be much appreciated.
http://www.4wd.com/?t_pn=EXP7425-E
« Reply #2 on: September 18, 2011, 09:58:45 PM »
