Author Topic: 95 2.5L Top End Rebuild: Push Rod question ???  (Read 6592 times)
Re: 95 2.5L Top End Rebuild: Push Rod question ???
« Reply #15 on: September 25, 2011, 04:27:22 PM »
Not sure but with a price of
289.00 and you need a Valve spring kit for
 89.00
378.00 seems kind of high for a cam
and you still need to get new lifters.
cheep performance = boom usually.. pay to play or stay stock
« Reply #16 on: September 25, 2011, 04:31:14 PM »
Forgot the lifter for $50.  Also may need new pushrods too.
So for me and the way the jeep is running now I'm not sure it would be worth it, cause its running good now.  Except that Exhaust leak.
« Reply #17 on: September 25, 2011, 04:35:30 PM »
if you don't do it right the first time you will just repeat what you did the last time. buy your self some time and be rebuilding again shortly down the road
« Reply #18 on: September 26, 2011, 05:31:05 PM »
Here is why I said it seemed high.  Got a reply back from comp Cams and I may go with this one.
Quote
I would recommend running #68-232-4 which specs at 206/212 @.050 460/476 113lsa
This cam is designed for fuel injected applications and has an 800-4800rpm operating range.
We do not offer this cam in a kit with springs and retainers, as you will need to get the springs, retainers, and licks from Mopar Performance or HESCO.
The cam and lifters combo runs $198.48 with free shipping in the U.S.
Please let me know what you think, and if you would like to place an order.
901-795-2400 ext 581
Thanks,
Chris Ryan
COMP performance group
Technical Department
3406 Democrat Rd.
Memphis,TN 38118
Phone: (901)795-2400 ext 581
Fax: (901)366-1807
cryan@compcams.com
www.compperformancegroup.com
« Reply #19 on: September 26, 2011, 07:41:27 PM »
Never mind my last post, they sent me the info for a 6CYL.   So it looks like they also do not carry anything for our engine.
« Reply #20 on: September 26, 2011, 08:21:52 PM »
that's a neat cam though, i wonder if thy have 4 cyl blanks, they can grind one to specs if they do.
« Reply #21 on: September 26, 2011, 09:05:05 PM »
Thats what I was asking them.  sent another E-mail out.
« Reply #22 on: September 27, 2011, 04:31:55 PM »
lol prob double the hesco price lol
« Reply #23 on: September 27, 2011, 05:16:38 PM »
the cam and lifters for the 6cyl at $198 - that's way cheaper than hesco. not sure what's the 4cyl one at if they have blanks or not, could be more pricey for a one-off, we'll see when grumpy hears back from them.
« Reply #24 on: September 27, 2011, 05:22:09 PM »
ya that's what I was implying.. asking the custom make one will be more then 200$ will prob make the hesco one worth second look.
not to mention they wouldn't have any testing done with it. so you would be the guinea pig.
« Reply #25 on: September 27, 2011, 05:33:40 PM »
Well got my reply and its still cheaper than Hesco.
Quote
My apologies, I thought the 4cyl said 4 liter.
We would have to do a custom grind for your setup on our 114-000-5 core.
The cam would run $194.62 with free shipping and would take 2-3 days to grind and ship out.
Thanks,
Chris Ryan
3406 Democrat Rd.
Memphis,TN 38118
Fax: (901)366-1807
cryan@compcams.com
« Reply #26 on: September 27, 2011, 08:16:30 PM »
you won't be a guineapig, the cams are the same just delete the middle 2 cylinders, plus they can probably add a bit more lift or duration or both if your valves and springs can handle it.
