Author Topic: Some engine issues- Need help  (Read 17277 times)
Re: Some engine issues- Need help
« Reply #60 on: November 28, 2011, 05:48:26 AM »
Ah cool Last thing, did you check to see if the tank had shrunk like mine and was pushing on the bottom of the pump? (It was the primary problem, I discovered the other stuff after I pulled the tank... :)
Wonder if your seeing a weak circuit in the ECU that cant drive the higher capacity coil?
Yeah,remember I had to changr fuel pumps 3 months ago...
