Author Topic: Weird revving  (Read 4145 times)
Re: Weird revving
« Reply #15 on: December 18, 2011, 01:34:54 PM »
The return spring on the TB looks good. I will check the carpet first to see if that is in the way and go from there. Pry grease up the pedal to see if that is the problem since I am there. Should be a beautiful 56 degrees out today!!!
Did you operate the throttle how smooth was it at the throttle body.  Its easy to pull the cable off and then move it thru its range of motion to see how it works.
