Author Topic: What grade bolt?  (Read 6350 times)
Re: What grade bolt?
« Reply #15 on: February 27, 2012, 02:32:35 PM »
Thanks for that information.
I finally found a 1/2" bolt this weekend, I was driving and suddenly saw a bolt and metal store and decided to cut across a few lanes or traffic and see what they had.
Got it installed and now it seems the fabricator did not put a sleeve all the way across so now I'm on a search for sleeve material.  It just goes on and on!
At least sleeve material is pretty easy to come by. Even pipe from the hardware store works (plumbing section) Plenty strong and cheap!
« Reply #16 on: February 27, 2012, 02:44:33 PM »
Sounds good, thanks for the tip.
« Reply #17 on: February 27, 2012, 02:52:56 PM »
as long as you find something close enough (but some machining might still be required) - not sure what his OD is but pipe standard for common sizes are
Size / OD / ID variations (3 or 4 different sizes)
1/4 / 0.540 / 0.410, 0.364, 0.302
3/8 / 0.675 / 0.545, 0.493, 0.423
1/2 / 0.840 / 0.674, 0.622, 0.546, 0.466
looks like 3/8 or 1/2 would be fairly close candidates
« Reply #18 on: February 27, 2012, 03:03:48 PM »
Good info.  Thanks
Will have to measure the OD but for ID the .545" looks good.
« Reply #19 on: February 27, 2012, 03:12:04 PM »
Good info.  Thanks
i would rather think .493 and run a 1/2 bit thru it from both sides. the 1/2'' bolt is not 1/2 inch but more like .490 or so (since i thought all this was related to the M12 vs 1/2'' which is about the same difference if you go with .545)
« Reply #20 on: February 27, 2012, 03:35:48 PM »
That's a good way to get the most snug fit.  Thanks for the idea.
« Reply #21 on: March 09, 2012, 02:41:25 PM »
The needed OD was 0.75 with ID close to 0.5 so no water pipes fit exactly (plus the 3/8 size was not to be found in several hardware stores including Home Depot).  Finally ended up getting a length of 0.75 OD, 0.52 ID seamless pipe that is supposedly used for hydraulic systems.  Weather has been cold and rainy here so might finally get it done in about a week.
Thanks for all the comments.
« Reply #22 on: March 09, 2012, 04:11:07 PM »
good find.
« Reply #23 on: March 21, 2012, 01:58:18 PM »
Update:
Finally got some time and good weather to get this rear support installed.  Thanks for all the comments and suggestions.
