Author Topic: 4 port nozzle injectors in a tj  (Read 5796 times)
cman
Re: 4 port nozzle injectors in a tj
« Reply #15 on: March 13, 2012, 05:17:14 PM »
Ok i get it now
Them ones i listed are just stock Dodge 1995-97 NEON DOHC Fuel Injectors
« Reply #16 on: March 13, 2012, 05:44:04 PM »
Ok i get it now
I meant the ones you listed here (didn't check the other ones, and to be honest these ones are good as far as flow with about a 5% increase over stock, i was wrong before saying it was minimal, Jeffy got the stock flow right at 23.2 for some reason i was remembering 24.2)
I did find these http://www.fiveomotorsport.com/jeep-23lb-fuel-injectors
cman
« Reply #17 on: March 15, 2012, 11:36:15 AM »
Does any one know any thing about these ones Accel #110-150124
http://www.jegs.com/i/Accel/110/150124/10002/-1?parentProductId=749691
cman
« Reply #18 on: March 15, 2012, 12:42:44 PM »
Does any one know if they are one nozzle hole or four nozzle hole ones
cman
« Reply #19 on: March 16, 2012, 08:53:29 AM »
was taking to ACCEL and they are the 4 hole hozzle ones thats good news
so witch ACCEL injectors should I buy for my 1998 JEEP TJ 2.5L
see i need new one of mine is bad wood you buy the accel 23 ones or the 24 ones or the 21 ones
Signature
Chris
North nova member
98 jeep TJ 4 cyl.rc 3.25 lift rear 3.50 rc/bds front,Adjustable track bar 1.25 body lift motor
lift durango box catback cold air-intake, Rugged Ridge 8500 winch 4.88 gears, 60mm TB & spacer Yukon locker solid diff covers M/T 32", JKS Disconnects Chromoly rear axles crossover steering
« Last Edit: March 16, 2012, 08:55:19 AM by cman »
« Reply #20 on: March 16, 2012, 10:00:51 AM »
it depends on what you're trying to achieve, both will work but
24lb/hr at 43.5psi would result in a 25.5lb/hr flow with the 49psi which is 10% over stock (imo this is too much)
23lb/hr at 43.5psi means you'll get 24.4lb/hr at 49 psi and that's 5% which is what i would go for but that's all up to you in the end
cman
« Reply #21 on: March 16, 2012, 12:56:10 PM »
ok thanks and accel to go to e-mail them and ask
http://www.hesco.us/shop.asp?catID=7533
did you see all the stuff they sell
headers and cams and stuff
and yes 5% to 7% is what i looking for
thanks i was thinking the 23 ones too
« Last Edit: March 16, 2012, 01:10:56 PM by cman »
