Author Topic: ring and pinion positives negatives/  (Read 3976 times)
Re: ring and pinion positives negatives/
« Reply #15 on: May 07, 2012, 01:04:01 AM »
Anybody use these guys.
http://eastcoastgearsupply.com/i-4764225-ford-8-8-rear-axle-bolt-in-yj-assembly.html
  Good way to get every thing I want Disk brakes and Locker while getting a stronger set up.  And its the 8.8
I bought the bracket set and gears from them. I'd suggest the truss from Ironrock as it's one piece and would be less labor than welding on seperate brackets. ECGS will set you up with a complete, ready to swap in axle with posi and disk brakes for around 1600 and a few hundred more for a locker. Still cheaper to pull it from a junk yard and just order parts from ECGS.
