Author Topic: Engine overhaul  (Read 5730 times)
Re: Engine overhaul
« Reply #15 on: June 16, 2012, 10:00:50 AM »
Sent another e-mail this time thru their contact page.  1st time was to their e-mail address.  Also told them there was a few of us here and told them where here was.
Re: Engine overhaul
« Reply #16 on: June 16, 2012, 10:58:21 AM »
Not sure I'm going to deal with them.  Their reply had less info than the ad.
Quote
Performance stroker kit comes complete
All pistons forged custom cam all bearings oil pump injectors timming set custom crank H rod 4340.
Sent from my Verizon Wireless BlackBerry
This was the question.
Quote
Would like more info on your 2.5/2.9 Stroker Torque Monster 5052.5.  What are Performance Brackets.  Do you have any more info on these kits.  Would like to know what they come with Any Pictures of these kits.  Do you have any reviews of these kits.
  Like the cam what else is required with this.  What does the cam come with.
Thanks.
« Last Edit: June 16, 2012, 11:01:42 AM by grumpygy »
Re: Engine overhaul
« Reply #17 on: June 20, 2012, 08:02:41 AM »
Well no more info came from them.  So did some more searching and seems that is a problem they have. Even complaints with the BBB.
Re: Engine overhaul
« Reply #18 on: June 21, 2012, 03:45:43 PM »
Well, then stroker kit is a no go...
I am still debating weather to get a new head or not (what do you guys think?), but the things I am considering at this time include:
Flowkooler High Flow Water Pump
PSC Motorsports Power Steering Pump
Probably a new oil pump (just in case)
As for other items I may need, what do you guys recommend (what and where to get it)?
I still need an overhaul kit (with all the gaskets and uch), pistons, rings, valves, etc.  I plan to use my cam (I put a new, more aggressive one in about 4 years ago, and it has seen only about 15K miles), as well as my roller rockers.  I already got the valve springs and retainers (was going to change them a while back, but never did).  Do you guys recommend a new head?  If so, where is the best place
Re: Engine overhaul
« Reply #19 on: June 21, 2012, 04:53:01 PM »
Just had my head redone.  Local Machinest did a great job and all it cost me was I think $80.  Reground the Valves and seat new seals and surfaced the head and both Exh and intake surfaces.
