Author Topic: Drivers door stuck closed  (Read 9906 times)
Re: Drivers door stuck closed
« Reply #30 on: January 28, 2013, 07:49:02 AM »
The trick that has worked for me when the door won't open from the inside is to put pressure on the lock/unlock toggle on the unlock side and at the same time pull on the lever.  When it has to be too often, then it's time to lube the mechanism.
« Reply #31 on: January 28, 2013, 08:05:02 AM »
If it happens again, it has worked for me several times to try and open the door and smack the door with my hand near the latch. I need to lube my stuff up. Just got my jeep back out of my shop after it sitting for 2 years and this was the first thing I had to do!
I even hit it with a large rubber mallet.
