Author Topic: Broken shackle hanger  (Read 5531 times)
Re: Broken shackle hanger
« Reply #15 on: August 23, 2013, 08:44:02 PM »
I went out and measured and the it was actually about 2.6.
that makes sense, i was off by quite a bit but even in this case would still be 73% less resulting force to the hanger (might be the make it or break it difference).
« Reply #16 on: August 23, 2013, 08:49:27 PM »
Finding a bit longer spring would fix it too.
Just a thought... how about welding a piece of tube to the frame angled down to where the shackle/spring eye would be at max flex. Sorta like \  Maybe it would prevent the shackle from inverting?
« Last Edit: August 23, 2013, 08:49:56 PM by FourbangerYJ »
« Reply #17 on: August 23, 2013, 08:56:24 PM »
The chain idea sounds pretty bootyfab.  I would go with the heavy duty shackle hangers as there are minimal welds holding the stockers on there.  Changing them out is not that large of a project.
« Reply #18 on: August 23, 2013, 09:36:12 PM »
or weld the h/d hanger a bit back and go with a longer shackle (would achieve the same result but get the stronger hangers on the frame).
« Reply #19 on: August 23, 2013, 10:15:25 PM »
Thanks for all the ideas and comments.  I'll have to let it all sink in for a while before deciding what to do.
