Author Topic: Axle shaft yoke contact  (Read 5303 times)
Re: Axle shaft yoke contact
« Reply #15 on: August 23, 2013, 08:24:59 AM »
When I replaced my axle shafts, I had the same problem; I had to put some washers and adjust the steering stops.  Since I had 31's at the time, there was no rubbing on the frame, but the yokes would make contact.
« Reply #16 on: August 23, 2013, 09:11:11 AM »
This is interesting.  What brand shafts did you install?
Thanks
« Reply #17 on: August 23, 2013, 09:17:47 AM »
Thanks
G2
« Reply #18 on: August 23, 2013, 09:21:22 AM »
They probably all come from the same place anyway!  :lol2:
I'll just adjust a bit more and check for rubbing.  Thanks
« Reply #19 on: August 23, 2013, 07:55:33 PM »
sorry neale, i had a full day and didn't get a chance to call them.
« Reply #20 on: August 23, 2013, 08:22:42 PM »
No problem.   After what jfrabat posted it makes more sense.
« Reply #21 on: August 23, 2013, 08:40:51 PM »
« Reply #22 on: August 23, 2013, 09:43:15 PM »
sound like you can take some material off to get more clearance but from the ears side, little bit there would probably give you back the difference so you don't have to add more shims under the stop.
« Reply #23 on: August 23, 2013, 10:10:58 PM »
That would be the best solution. Might get around to it sooner or later. Maybe some 35s would solve the problem  :pot:
