Author Topic: Hesco  (Read 3126 times)
Hesco
« on: November 20, 2013, 07:04:34 PM »
Want to pass on a low price at least lower than any other I've found and to ask is this one that will work with the 2.5.
Quote
91-95 Fuel Pressure Regulator #HES9195FR
Price: $179.00
Description:
Adjustable fuel pressure regulator for 1991-1995 4.0L & all 4.2L jeep engines with MPI regulator on the fuel rail. Designed to increase fuel pressure to eliminate lean running conditions. The regulator is pre-adjusted to 44psi. and should not require further adjusting. This is a high performance part.
Note: Due to the hold down bracket becoming obselete the kit will no longer contain this part. The consumer will need to increase the inside diameter of the bracket to fit over the regulator body. This can be accomplished with either a die grinder or file will minimal effort.
SPECIAL SPRING PRICING!!
Re: Hesco
« Reply #1 on: November 20, 2013, 08:04:37 PM »
it works on the 2.5
Re: Hesco
« Reply #2 on: November 20, 2013, 10:19:44 PM »
Thanks
Re: Hesco
« Reply #3 on: November 21, 2013, 06:16:23 PM »
Well its on order.
Re: Hesco
« Reply #4 on: November 21, 2013, 08:16:21 PM »
i hope it comes with o-rings (common problem with pressure bleed when stopped).
Re: Hesco
« Reply #5 on: November 22, 2013, 07:37:24 AM »
Which O rings internal or the two you can see.
Re: Hesco
« Reply #6 on: November 22, 2013, 07:48:51 AM »
there are only 2, one on the nipple (small) and one on the large diameter, usually the small one goes bad without noticing (the large one would cause a leak you can see or smell).
Re: Hesco
« Reply #7 on: November 26, 2013, 03:52:05 PM »
It came with new O-rings.  Will put it on this weekend.
Re: Hesco
« Reply #8 on: November 27, 2013, 05:08:30 PM »
Now I have to grind the Bracket.  Was hoping it would go together without that.
Re: Hesco
« Reply #9 on: November 27, 2013, 07:38:25 PM »
is it larger diameter?
Re: Hesco
« Reply #10 on: November 27, 2013, 09:59:17 PM »
Yep.  They do have a warning on their web site you will need to use a die grinder to open it up so theirs fits.
Quote
« Last Edit: November 27, 2013, 10:14:01 PM by grumpygy »
