Author Topic: Roller Rocker ID help  (Read 4598 times)
Offline bigal389
Re: Roller Rocker ID help
« Reply #15 on: December 02, 2013, 09:15:36 PM »
Mine are 1.6's also.
87 Jeep Yj 2.5 all stock for now
Offline aparke4
« Reply #16 on: December 08, 2013, 09:10:27 PM »
I just installed yella terra 1.6 RR's and they look exactly like the ones you posted.
Performance wise I have only driven around the block but the idle is smoother and the jeep revs to 3k much easier. I have a bunch of other mods so I am hoping this brings everything together!
I am looking for a mild cam- do you think you are going to pull the trigger on the one you posted?
Offline bigal389
« Reply #17 on: December 09, 2013, 11:14:32 AM »
Yes I am planning to get the cam I posted the info on but it may be after the first of the year before I can. I have had to put my plans on hold for a little while, my 18 year old son rolled his 4runner so I'm working on him another vehicle right now.
Al
Offline aparke4
« Reply #18 on: December 12, 2013, 04:35:00 PM »
right on- i actually like to torque/ hp curve as is but I really need to get it dyno'd to see if all my mods actually did something. moreover, i would like to see how a cam could/ would benefit from my motor mods. The last option before a tdi swap would be a very low psi turbo set up (5-6 max psi). With the e fan conversion I have tons of working room! That is a dream though- as of now it drives great with the 4.88 gears, bolt on motor mods and lightweight wheels and AT's.
