Author Topic: Has anyone re-wired their Jeep?  (Read 1345 times)
Offline bootguy
« on: April 10, 2015, 12:16:08 AM »
I have been fixing wiring issues on my jeep for a while now.  Has anyone done a complete re-wire using pre made wiring harnesses?  My fuse block in the cab needs to be repaired/replaced as some contacts have broken.  The fuse block in the engine compartment is cracked and broken and have used duct tape to keep water/moisture out.  Since I have quite a bit more to fix just wondering if complete replacement is as easy as the vendors claim?
Re: Has anyone re-wired their Jeep?
« Reply #1 on: April 10, 2015, 09:55:42 AM »
it's not hard but for inside (in-cab) you'll probably need to take the dash off so you gain access to the harness, engine bay is quite easy
all of course with an original or new replacement harness.
