General Forums > The Mess Hall
Learning to Weld
(1/1)
Jeffy:
Looking to finally get a welder. I'm thinking about a Millermatic 211. I've got 240v here and from all I've learned, a 240 MIG will do basically everything that I would want, or need to do. Hopefully, I can get a decent price for one in the coming months. There's a pretty decent discount right now but I think I'm going to miss it.
What I question on is all the other gear though. What do you recommend for everything else? I'm probably going to splurge and get an auto-dimming helmet. Not sure which one though. Gloves, wire, cylinder size, etc...
Jeffy:
Been able to practice welding for a few hours every week for the past 3 weeks. Using a Millermatic DVI2. Not really sure of the specifics of the machine but it does weld. The sire speed and voltage are kinda weird though. Voltage is labeled 1-6 so there are no fine adjustments. Wire speeds are 1-100. Kinda wish they would use the more standard Volts and WFS.
Jeffy:
First welds in almost 30 years. Looks like crap but also not that bad for the first time.
The second time. Basically, I get a few hours a week. I think I was having gas flowrate issues.
Third week. Still playing around with settings. The welder is a Miller DVI2. The controls are kinda weird in that there isn't an actual voltage. I've got 6 positions to choose from. Wire speed is 10-100. May have still had some gas flow issues.
Week 4. Had a guy help me set up the welder. Was pushing the machine harder than it needed. A bunch of HS kids also use the machine and change all of the settings all the time. I've always gotta clean up after them before I can do any welding. Lowered the wire speed and voltage and it welded a lot better. Kind of counterintuitive. Hoping to get decent before getting my own welder. I'm looking at the Millermatic 215. They have a stick welder and a TIG so once I get better at MIG I'll probably switch over to one of the others.
Jeffy:
Pretty much have been welding once a week since then. Here's my very first project. This was maybe the second week in. Looks like crap but it's holding. I'll probably redo it when I do more work on it soon.
This was in early February.
Then late last month, I figured I needed to fix my shock issue. Up to this point I had been welding on a bench. It was completely different having to shove my head into the wheelwell.
There's some poracity here but it's only that scraggly line. I ground it out.
The welding part is easy compared to having to match the two sides.
Navigation
[0] Message Index
Go to full version
