Author Topic: CB radio  (Read 10660 times)
Offline dexetr30
  • 4BangerJP.comŽ Donator
  • Aloha Mr. Hand!
Re: CB radio
« Reply #30 on: March 28, 2007, 06:54:04 PM »
Isn't all that kind of dieing off more and more as the Internet/IM get more popular? I don't know much about it, but that's what I have heard.
When the power goes out, there is no Internet.  Amateur Band is still active in the Emergency Communication as well as for regular long distance communication.  Actually, it became a bit more popular in recent years as more offroaders switch to 2M from CB.  It offers everything CB does plus more without having to deal with the limitations of CB.  Still most people don't have 2M so CB is also used.  The Leader and tail gunner can fairly easily stay within contact without any troubles with 2M.  For several miles I'll use as little as .5w to talk to people.  5W for the teens and up.  I've rarely used 25W or even 50W unless they are really far away.  Even over a mountain 10w works fairly well.
2m is nice. Gotta check the requirements for it and maybe take the test.
Guardian7
Re: CB radio
« Reply #31 on: March 28, 2007, 07:51:07 PM »
I just want to provide some performance tips for those who may be adding a CB and don't want lots of problems.
I don't run power or encourage anyone else to, my own is Cobra75WX all in the mic CB unit using all surface mount technology and none adjustable but great for space constraints. I do know that factory modulation limiters keep the modulation down to about 60% to prevent bleed over into harmonic frequencies such as TV which is the 2nd harmonic of the Citizen band. On better models like the Cobra GTL & LTD Series these are adjustable by trimpots. If you have a scope to watch your clipping it's nice but cleaner input modulation is a big key too which is why the D104M6 is a good choice over stock mics. They can sound different depending on make and model of the radio and even the astatic mics themselves vary. The power mic level and radio mic gain settings all play a big part in sound just as final output power of the AM transmitter does. Many people tweak up the power on CB's which actually works against the modulation circuit and creates more distortion. By turning down the power more modulation can be injected into the final transmitter circuit and will sound less tinny and allow for more amplitude during modulation so a 4 watt CB set to 2 or 3 watts still puts out the same amount of power when modulated by design but sounds much better. My own CB is used only during off-road events and still seems to be the cheapest and easiest way to add communications to your my which also seems to be what most Jeepers are still using these days. Many CB's today do not have metal chassis with knobs mounted to the front chassis frame and wires to the main board, but use a front circuit board with knobs or buttons soldered to it, problem there is vibration destroys this design faster and also hard impacts to the knobs making repair near impossible.
Re: CB radio
« Reply #32 on: March 28, 2007, 08:21:11 PM »
if it's a small cb mount it under the centerconsole part of the dash take the rubber pad out of the storage part of the center consoleright in front of the shifter run the wires there and stick the back end of the cb in that. then mount to the bottom part of the center piece of the dash.
Thus should give you an idea.
http://tinyurl.com/293w73
Art
Guardian7
Re: CB radio
« Reply #33 on: March 28, 2007, 09:38:08 PM »
Mine has a Tuffy center console with an XM receiver mounted in front of the shifter so I just went with all in mic unit after some frustration with finding mount spot. Being able to remove and store the CB in the glovebox is nice too.
Offline dexetr30
  • Aloha Mr. Hand!
Re: CB radio
« Reply #34 on: March 29, 2007, 07:31:24 AM »
I need to find somewhere to mount mine that I find acceptable. I've mocked it up a few different ways and it always looks bad. I like the mount on the center console by the drivers feet but I'd more than likey kick the tar out of the radio. Maybe I'll fab some kind of overhead rack that goes between the roll bars above the drivers head.
Re: CB radio
« Reply #35 on: March 29, 2007, 09:20:30 AM »
I'll try to snap a pic of mine and upload it this evening, I am 6'1" and couldn't mount it on the driver side because I would kick it so I mounted it it on the passenger side.  It looks fine and I can reach it with no problem
Liljeepz
Re: CB radio
« Reply #36 on: March 29, 2007, 06:41:06 PM »
Quote
Weird... I'm 6'5" My legs don't ever touch it... I didn't buy a bracket, I just screwed the one it came with to the plastic, and it has held so far no problems. :thumbsup:
Liljeepz
Re: CB radio
« Reply #37 on: March 29, 2007, 06:49:37 PM »
I found this pic... doesn't show to much... Ill take pics tomorrow when its light out side of my CB location.
