Author Topic: shift knob woes  (Read 1318 times)
absplatty
shift knob woes
« on: June 25, 2006, 08:21:11 PM »
hey, has anyone swapped a shift knob on a 99 TJ with a manual tranny?
i'd assume that all the manual TJ shift knobs would be the same...
my bro brought me home a sweet little doo-dad from work that i want to fab up to be a shift knob, i just cant get the stupid stock one off  :?:  :?:  :?:
i already did a search, but that didnt bring up anything that would help
Liljeepz
shift knob woes
« Reply #1 on: June 26, 2006, 04:41:08 PM »
Quote
I think you need to pry up the center cap on it (the deelly with the shift pattern) and there should be a nut there to remove.
Quote
The older ones had a lock nut on the bottom that had to be loosened first before unscrewing the knob. But I think the one you have has the locking nut under the cap like sunder said.
Quote
you have to pry up the cap on the stick - use a fine flat head screwdriver and work all around the cap to pry it up - it won't come up just by digging it in one side and prying like a crowbar -- after that its a nut to remove and the knob should pull off
I copeyed those off another website forum.
So I can't take any credit.
absplatty
found it!
« Reply #2 on: June 26, 2006, 08:17:29 PM »
actually, i wrapped the shift knob in a rag and grabbed it with channel locks, then lefty loosey and it came right off
i'll post some pics tomorrow hopefully.
it looks tight.
