Author Topic: Need Shocks  (Read 1565 times)
bluebanger
Need Shocks
« on: July 19, 2006, 03:42:43 PM »
I am new to the offroad world and need some help . I have a 87 yj that I have put a SOA conversion on and also 2" shackles my problem is I dont know what shocks I need . I called summit and they told me to measure compressed and extended lengths. I am not sure how to do this. If anyone is running the same set up or around 7.5" or 8" of suspension lifht please let me know what Shocks I need to run.
SMC4WD
Need Shocks
« Reply #1 on: July 19, 2006, 03:51:52 PM »
There isn't an easy way to do this but to cycle your suspension.
Get it up on a lift and let the axles hang.  Make sure your brake lines, breather tube or anything else that can rip out is secured.  Simply measure the distance from mounting point to mounting point.
Compressing the suspension isn't as easy.  Try to articulate the suspension.  Run it p a ramp or loading dock.  By drive up the front end first, measure the most compressed side of the rear shock mounts (Good time to address bump stops too!).  Back the rig up and do the same on the front measurements.
There's your extended length and collapsed length.  It's not easy, but it's far more accurate than someone else's set-up on your rig.
