Author Topic: KC hi-lites install  (Read 2317 times)
tanbuffsidriva
KC hi-lites install
« on: October 18, 2006, 02:03:56 PM »
ive got the 100w set of kc hilites . for anybody whos installed these, where did you mount your switch? just looking for some ideas. the install seems like it should be pretty easy
  • Poseur ExtraordinaireŽ
KC hi-lites install
« Reply #1 on: October 18, 2006, 02:25:59 PM »
I am only using 2 of the 3 spaces I have for switches on my TJ (rear wiper and rear defrost).  I just took the assembly out and drilled a hole in the blank one in position 3 for the hi-lites.  Had a hard time getting the wiring to reach that far though...across tot he battery...across the front to the firewall hole...back across to the middle for the switch.
KC hi-lites install
« Reply #2 on: October 20, 2006, 03:06:11 AM »
Mine began life as a hardtop, so I took out the factoty swtch panel and milled myself a new one.
DemonicHuey
KC hi-lites install
« Reply #3 on: October 20, 2006, 06:08:35 AM »
i first installed a double tuffy overhead for my CB and deck......i took out the old radio...installed a 16gage steel panel where that would go and hooked up my KCs switchs....with the other lights installed,,,,(rock lights and hellas) i really made a good look for everything and my Deck wont be a out in the open :D  :D
