Author Topic: Mobil 1 "0W 20" synthetic oil  (Read 4255 times)
chrisfranklin
« Reply #15 on: January 21, 2007, 01:38:10 AM »
So, I am using this 0W20 stuff now, I have to admit it is nice.  The oil seems like it circulates instantaneously, etc.
However, I was doing some reading which suggested that 20W oil used to be used on new engines to help cause slight metal-to-metal contact between pistons and cylinder walls, essentially breaking the engine-in.  This is not such a big deal with newer engines that have tighter cylinder clearances.  However, the old Jeep 2.5 is likely no poster-child for tight cylinder clearances
As such, I might stick with the 0W20 for 5-10,000 miles, but at the next change go to a 0W30/5W30 or higher to put a little more lubricant between the pistons and cylinder walls.  May even give the Amsoil Synthetics a go (since this is supposedly a true synthetic and not derived from forms of petroleum, unlike Mobil 1 or Castrol)
Note:  Course, some say that modern 0W20 synthtic is a different breed from the old 0W20 break-in oils:  it flows great, takes the high heat, doesn't get to thick at temperature, thus minimizing drag.  Still a very thin oil, but no metal to metal occurs    This 20W "engine-wear" issue seems to be an ongoing argument on some boards out there, typically ford mustang, race car sites.
wrangler387
« Reply #16 on: January 21, 2007, 09:46:41 AM »
Send in a sample of your oil for an analysis, that will tell you if it is truely too thin. I think you will be fine though.
