Author Topic: "DIY Jeep painting and color matching" Follow up  (Read 27900 times)
chrisfranklin
Re: "DIY Jeep painting and color matching" Follow up
« Reply #60 on: October 23, 2007, 09:07:28 PM »
another shot
[attachment deleted by admin]
« Reply #61 on: October 24, 2007, 05:23:25 AM »
Why did you have pigment added to primer?
chrisfranklin
« Reply #62 on: October 24, 2007, 09:44:02 PM »
The Bullseye 1-2-3 Primer/Sealer is White.  My paint is Gloss Black.  The tint aids in the reduction of the number of coats of the topcoat paint needed for "coverage" in my case.
If I was going to do a white topcoat, I wouldn't bother tinting obviously
« Last Edit: October 24, 2007, 09:47:56 PM by chrisfranklin »
chrisfranklin
« Reply #63 on: October 29, 2007, 07:00:32 PM »
This roll paint project aint a good idea if you have a short attention span.   :lol:
After the Evercoat, I did 2 coats of white primer, then sanded.  Then I did 2 coats of sealer (Bullseye 1-2-3, the Tintable kind designed for dark topcoats) to serve as a barrier between the water based primer I inadvertently used and the polyurethane, oil-based top coat paint I have.
So I am sitting around getting ready to sand the sealer this evening -- you know just to get out any orange peel and make it a nice smooth surface for the topcoats.
I didn't think much of sanding the sealer because the guy who did the white corvair w/Rustoleum had apparently sanded down his primer before topcoating.  Me, I was thinking: "Primer/sealer, what's the difference? you just want a smooth surface for the topcoats."
Well, according to some forums, "Sealer" is an "animal" different from primer.  Some suggest that when you "sand" sealer, you effectively "break-the-seal."  So you may not want to sand it.
I am kind of on the fence on this one.  But I am probably going to end up leaving my coats of sealer "as-is" and just get on with the topcoats. May not be quite as smooth or could be ok and I actually find that the unsanded Sealer provies a better bond with the topcoat paint.   :bore:
