Author Topic: B&M Ripper Shifter  (Read 15275 times)
Oilsmoke
B&M Ripper Shifter
« Reply #15 on: September 26, 2005, 06:02:44 PM »
You are right about the Bolts. They where 45mm long, I went to the hardware store and bought 4, 60mm long and had 3 threads showing under the housing.
  The cut you are talking about Does serve a purpose in which it’s designed for. The Ax5 with stock transfer case & shifter. The Transfer case shifter mounting bracket fits perfectly in it and supports the housing from tiling as you stated. If you are not using this bracket than other style may have been a better choice.
 Some ultra black sealant and not a leak anywhere.
AS for fit I must be an Ape with long arms Mine fit me great. :)
jeepfourlow
B&M Ripper Shifter
« Reply #16 on: September 26, 2005, 10:26:32 PM »
hey oilsmoke did you ever install it?
Oilsmoke
B&M Ripper Shifter
« Reply #17 on: September 27, 2005, 03:17:48 PM »
Yes I installed saturday morning. Appox 2 hours but I clean the guts out of the shifter housing and made 2 trip to the hardware store.
Personal I think it great. I wrote alittle review in the other forum.
