Author Topic: Turbochargers  (Read 201049 times)
chrisjsmith4
Re: Turbochargers
« Reply #345 on: May 07, 2010, 07:33:06 PM »
Ya. If I did the v8 swap I would find a donor dodge. harness is just a matter of changing a few sensors and plugs to work with my own gauges. but I would have everything I need off the donor vehicle. I don't know. just a thought. check out this site-- http://www.burnsvilleoffroad.com/articles/00_12.aspx
I have ftc1-019b
Red Wire (b+)- fused ignition switch output
black (b-)  - sensor ground
violet - map sensor signal
grey- leading to crank sensor
grey/black- leading to pin 24(crank sensor input)
tan- leading to cam sensor
tan/yellow-leading to pin 44(cam sensor input)
vacuum line -- Where to put for best reading?
Re: Turbochargers
« Reply #346 on: May 07, 2010, 07:43:37 PM »
I have ftc1-019b
put the vac line exactly where your current MAP sensor is - and if it is on the t/b you can take it off and use that port. you can also use a T type fitting to split one of the vac ports in the intake manifold  from right under the t/b.
chrisjsmith4
Re: Turbochargers
« Reply #347 on: May 07, 2010, 07:51:20 PM »
ok sounds good. I'm sitting here with the controller in my lap and i am noticing an orange wire and a yellow/black wire that I don't know what they go to. nothing on the instructions for those wires
chrisjsmith4
Re: Turbochargers
« Reply #348 on: May 07, 2010, 07:54:23 PM »
I just cross referenced the pin out connections and came up with what you have.
Re: Turbochargers
« Reply #349 on: May 07, 2010, 08:34:38 PM »
yellow/black is for tach signal but in your case you use the cam signal and you set the engine as 1 cyl 4 stroke in the software (if i remember correctly, should be on your install sheet)
orange is for an external load - can control a relay so you can for example run a alcohol or methanol injection system or a signal modifier trigger (like if you want to alter the o2 sensor output) - this can be triggered based on an rpm and pressure basis as and you set it up under options > output settings > Output B
chrisjsmith4
Re: Turbochargers
« Reply #350 on: May 07, 2010, 09:39:13 PM »
oh ok. thanks. I'll just cap them off.  thanks for your help
Re: Turbochargers
« Reply #351 on: May 07, 2010, 10:17:57 PM »
no problem
get it hooked up and take it to the dyno - you're like right there. My guess is that they'll tell you to get bigger injectors, but might as well finish it now and if you're not happy get the 4.7L and sell your setup.
Vodkaman
Re: Turbochargers
« Reply #352 on: May 09, 2010, 11:12:05 PM »
...and if you're not happy get the 4.7L and sell your setup.
No!!! Don't do it. So far, your set up is the fist made for TJ in a proper way. Finish it Chris, I'm sure there will be followers, at least one in Moscow ;)
« Last Edit: May 09, 2010, 11:14:23 PM by Vodkaman »
chrisjsmith4
Re: Turbochargers
« Reply #353 on: May 10, 2010, 07:46:37 PM »
I can't remember if I told you guys this in the past threads but i'm also still having a problem with a 02 heater circuit code. p0135. I can't figure it out. I've bought 3 02 sensors and all anyone can tell me is that it is an 02 problem. I had it diagnosed and that guy told me to buy one from jeep(cost a pretty penny). I'm lost. I feel i can't move forward without that fixed. Air sierra never had this problem so I'm guessing that it isn't because of not having the pre-cat. i'm still trying to figure out the intercooler as well. and i already have bigger injectors. 27# vs. 22#. i can smell how rich it is when i'm idling.
Thoughts? Ideas?
Re: Turbochargers
« Reply #354 on: May 10, 2010, 08:11:52 PM »
Thoughts? Ideas?
P0135 Oxygen Sensor Heater Circuit Malfunction (Bank 1 Sensor 1) - not sure why you would get that, maybe a bad ground but dunno to be honest.
if it runs rich at idle is either the O2 sensor or you should get a too large afr correction factor error code (means the PCM cannot adjust the afr that much, so the fuel trim is outside the acceptable range) - one thing is to do a full computer reset (not sure how you do it on your year of vehicle), the other thing is the FTC1 will allow you to adjust the MAP sensor output to match the required fuel quantity (tricking the PCM in thinking it needs less fuel by reporting a lower MAP reading) and in that case the fuel trim should come back within the normal range.
EDIT: an ODB2 scanner will allow you to monitor the fuel trims, that is one of the ways the Split Second recommends tuning your unit - check the Underdog Racing Development engine tuning guide on their site.
« Last Edit: May 10, 2010, 08:13:49 PM by sharpxmen »
Re: Turbochargers
« Reply #355 on: May 15, 2010, 11:10:32 PM »
@chrisjsmith4: any updates?
chrisjsmith4
Re: Turbochargers
« Reply #356 on: May 16, 2010, 04:22:08 PM »
No updates. i've been lazy lately. I ran a half marathon yesterday and have been training for the last several weeks. Now I have time in the afternoons to do stuff. My work load will also be decreasing. I have also accrued enough money to get the RE 3.5 basic lift and 32-11.5 tires for it. just need to get work on the jeep. i'll keep you guys posted
Re: Turbochargers
« Reply #357 on: May 16, 2010, 08:26:08 PM »
dunno about you but last time i checked running 1/2 marathon was not in the lazy isle :lol:
chrisjsmith4
Re: Turbochargers
« Reply #358 on: May 16, 2010, 10:58:09 PM »
True. I got my intercooler in today. It is completely redneck but thats ok. I used a top mount intercooler off a wrx and put it where the stock intake sits. probably not going to do any good there but it something. i should do the set up like airsierra. his looked nice. I also checked the ground on the O2 and had tone. It also has 13 volts going to it and its signal varied between .2 and .9 is this right?  I wonder if i should try plugging in a different ecu if i can find one. maybe mine has gone haywire.
Re: Turbochargers
« Reply #359 on: May 16, 2010, 11:44:42 PM »
i think it goes from .05 to .95 but .2 to .9 sounds about right. there are 2 grounds on the O2, the thicker wire one is the heater ground, the other one (which i think is black/blue) is the sensor ground. I know you have 2 O2 sensors, did you check both?
