Author Topic: Turbochargers  (Read 209936 times)
chrisjsmith4
Re: Turbochargers
« Reply #360 on: May 17, 2010, 01:54:19 PM »
I didnt check both. I think only one ground grounds at the battery. all 4 wires are the same size. one wrie is fused relay. one is sensor ground. ground then sensor signal. thats what the pdf said
Re: Turbochargers
« Reply #361 on: May 17, 2010, 03:03:51 PM »
did you replace both O2 sensors (you said you replaced the O2 twice, not sure if that meant both or the same one twice).
chrisjsmith4
Re: Turbochargers
« Reply #362 on: May 17, 2010, 06:24:05 PM »
replaced the same one i think 3 times
Re: Turbochargers
« Reply #363 on: May 17, 2010, 06:57:22 PM »
use one of the ones you took out and replace the second one - maybe that's the one with the issue and you were replacing the one that was fine - just a thought
chrisjsmith4
Re: Turbochargers
« Reply #364 on: May 17, 2010, 07:05:59 PM »
I'll see if one will fit. I know there are two different part numbers. its cooling down right now. i'll check in a bit
chrisjsmith4
Re: Turbochargers
« Reply #365 on: May 17, 2010, 08:13:03 PM »
It won't work. The plugs are different. i'll have to buy another one which sucks.But I did test the ground which had tone so thats not it.
chrisjsmith4
Re: Turbochargers
« Reply #366 on: May 26, 2010, 06:28:23 PM »
Took the Jeep back to the evil man and ran some more tests. He ran me through the tests on checking why the heater circuit code is tripped. Everything checks out fine so he recommends I get the PCM flashed or getting a new one. New ones are 300 and to flash is 80. I think I'll go with the flash. I'll have the fuel controller in this weekend and i'll take pics . Finally have time to get some stuff done.
Re: Turbochargers
« Reply #367 on: May 26, 2010, 07:01:20 PM »
Try eBay for the ECU; I found one for my Jeep for $50 or so...
Re: Turbochargers
« Reply #368 on: May 26, 2010, 08:02:30 PM »
unless there's a newer firmware revision that addresses that bug (assuming it is a bug) flashing won't change anything
chrisjsmith4
Re: Turbochargers
« Reply #369 on: May 27, 2010, 07:15:19 PM »
I'm thinking maybe I messed something up when i installed the turbo and didn't have an 02 sensor in.
Re: Turbochargers
« Reply #370 on: May 27, 2010, 11:30:55 PM »
worst that can happen is that it would store a code and that can be reset with the scanner by the evil man
chrisjsmith4
Re: Turbochargers
« Reply #371 on: May 28, 2010, 09:46:15 PM »
I'll check ebay for one first then.
chrisjsmith4
Re: Turbochargers
« Reply #372 on: May 29, 2010, 02:11:02 PM »
A couple pics of the intercooler set up
Re: Turbochargers
« Reply #373 on: May 29, 2010, 02:59:24 PM »
there's no airflow in that spot, so once the i/c gets hot (which is about 15 seconds under boost) it won't cool anything - maybe have a grill on top of the hood with a fan on top of the intercooler blowing thru downwards.
not trying to put down what you did but the way it supposed to work is by having cooler air thru the fins to remove the heat buildup that was transferred from the intake air into the intercooler tubes - the way you have it won't cool at all, you can test that by having a temp sensor ahead and after the intercooler. Subaru (if i remember that's where you got it from) has an air ram vent on the hood pushing air thru the i/cooler.
chrisjsmith4
Re: Turbochargers
« Reply #374 on: May 29, 2010, 05:27:44 PM »
Ya. I'm gonna find a fan to put on it or just do an water to air intercooler. Its just acting like a makesift radiator right now. I noticed a difference right off the bat with how it ran. Its just temp.
BTW. got the fuel controller hooked up just now. Gonna start it here in a few minutes.
