Author Topic: ECM voltage regulator  (Read 1204 times)
Offline dexetr30
  • 4BangerJP.comŽ Donator
  • Aloha Mr. Hand!
« on: August 08, 2007, 12:29:30 PM »
Does the TJ ecm have a seperate voltage regulator (aside from the one contained in the alternator) like the yj ecm's have? I've replaced my alternator and battery and want to know just in case I have a voltage problem in the near future. If there is a regulator in the ecm and I end up having to replace it (ecm) ... is there anywhere online that would be a reliable source to go to or should I just go to the dealer?
