Author Topic: D30 gear choices  (Read 4189 times)
Re: D30 gear choices
« Reply #15 on: September 07, 2007, 03:06:47 PM »
I run 35" and 36" tires with my 5.38 and I'm very happy with my rpm range and ability to accelerate on the highway.  I would definately be wanting more if I had 4.88 gears.
You can take the old spring perches off with a 4.5" angle grinder fitted with a cutoff wheel, generics run about $20.
I would recommend bolting up your axle with new ubolts, rotating the axle for proper pinion angle (to your liking), then trailer it to a welder.
