Author Topic: Idle Issue  (Read 9761 times)
garydubf
Re: Idle Issue
« Reply #45 on: December 28, 2007, 12:12:55 PM »
I don't see why not!  I'm using a MSD coil, with Mopar performance wires.
Desert Bob
Re: Idle Issue
« Reply #46 on: January 12, 2008, 10:12:37 PM »
I put in a new Acel coil.  No change.  Arrrrg!  I might as well change the CPS as this is the only thing I haven't replaced.  Then at least I know I have done my best.  Please any other ideas?
95yj4
Re: Idle Issue
« Reply #47 on: March 16, 2008, 10:23:44 PM »
I had a similar situation, but mine eventually turned into it dying while running, especially at idle. Try checking the input wires to the coil, follow them as far as they go. On mine there was a tap comin off the power side that the person before me put on for some ungodly reason. The tap eventually broke the wire but they were close enough that it actually made contact most of the time.
