Author Topic: Follow on to the previous 2.4L Peformance question  (Read 1501 times)
chrisfranklin
« on: October 10, 2007, 12:24:12 AM »
I think of getting performance out of a 4Banger, old or new, I think engine modifications (or, thanks to the guys here, Gearing).  If we were talking a different vehicle, then maybe I'd think shedding weight, too, so the engine doesn't have to pull as much.
Recently there has been some talk here about automated manuals, paddle-shift etc and that probably caused me to remeber that I hadn't changed out the gear oil on my 4Banger's 5speed and transfer case in about 50,000 miles.  I did that the other day and I also did the differentials, too.  I ended up using a Royal Purple Synthetic Gear Oil all around, about 10 quarts of the stuff!
After doing the gear oil change, I noticed that I was able to change gears about half-again as fast as before (Obviously no supercharger-type power improvements to the rear wheels, etc; just faster gear changes).  With the faster shifts, it seems your RPMs don't have as much time to drop as you upshift.  Thus your engine is in a slightly "meatier" position as you are able to advance more rapidly through the gears.
Changing to a good synth tranny fluid is not real expensive and it may help you use your engine a little better. :biggrin:
Offline lax22
Re: Follow on to the previous 2.4L Peformance question
« Reply #1 on: October 10, 2007, 07:55:48 AM »
I am glad to hear that worked for you.  :thumbsup: But i think performance in that case would depend on how bad the fluid was in there before you changed it. If it was old and broken down real bad, even just putting fresh oil in would be an improvement. I would like to try the royal purple stuff though, too bad its not sold locally and i dont like the idea of mail ordering oils. But good job  8)
