Author Topic: A tip for the automatic guys  (Read 1659 times)
Rob the plumber
« on: November 10, 2007, 01:14:01 PM »
I have a 1995 YJ with a 2.5L and an automatic. I am running 35" tires and stock 3.73 gears. Acceleration is pretty pathetic as you could imagine. Around town it is fine, but keeping up with freeway traffic can be a chore. I hooked my torque converter clutch up to a dash monted toggle switch. The TCC clutch is also controlled by the brake light switch. I found a black ground wire in the pigtail going to the brake light switch that disengages the clutch when the brakes are applied. Now when I am driving at higher speeds I can shut off the TCC and get more power out of the Jeep.
I don't think it hurts mileage much because I use much less throttle to maintain speed.
Offline dexetr30
  • 4BangerJP.comŽ Donator
  • Aloha Mr. Hand!
Re: A tip for the automatic guys
« Reply #1 on: November 10, 2007, 02:11:09 PM »
That is a pretty good tip. Even with 29's I find my TJ bogging down when the converter locks.
lanulos89
« Reply #2 on: November 10, 2007, 05:19:36 PM »
got  a write up or a how to???
Rob the plumber
« Reply #3 on: November 11, 2007, 05:27:08 AM »
I'll try to snap a picture of the harness later today.
