Author Topic: Premature Clutch Wear - Tech Bulletin?  (Read 2756 times)
Desert Bob
« on: November 29, 2007, 12:16:49 PM »
I am in need of a new clutch and stumbled accross this technical notice.  Is any one running this spacer in their 94-95 Wrangler and if so did it make a difference:
Vehicles: 1994-98 Jeep Cherokee, Grand Cherokee, Wrangler
LuK Part Numbers: 01-040, 05-065, 05-901
Premature clutch wear may be caused by insufficient clearance between the bell housing and slave cylinder. The slave mounting surface is located too far forward, restricting movement. This prevents proper fork move-ment, causing partical release and slippage. Install a shim, Jeep part #4797072 between the slave cylinder and bell housing to avoid premature wear.
For additional information, refer to Chyrsler bulletin #06-03-94.
http://perfectionclutch.com/PDF/IB%20152-Chrysler-Dodge-Jeep.pdf
http://www.lukclutch.com/support/bulletin_detail.phtml?number=LB154
For application, diagnostic or installation questions, call the LuK Technical Hotline at 800-274-5001, 8:00 a.m. to 6:00 p.m. ET Monday through Friday, or check online at www.lukclutch.com under TechnicalBulletin
Schaeffler Group USA Inc.5370 Wegman DriveValley City, OH 44280Phone800 274 5001Fax330 273 3522Web www.lukclutch.com www.lukprogold.com
« Last Edit: November 29, 2007, 12:23:10 PM by Desert Bob »
