Author Topic: Heater won't shut off.  (Read 1101 times)
Offline dexetr30
  • 4BangerJP.comŽ Donator
  • Aloha Mr. Hand!
« on: January 08, 2008, 05:07:47 PM »
I went to turn the heat from the floor position to off and it just kept blowing. Lately every once in a while I've heard a hissing sound coming from behind the heater controls. Does anyone have any advice on what to look for?
flyingbrick
Re: Heater won't shut off.
« Reply #1 on: January 08, 2008, 05:34:56 PM »
vacuum leak in the heater control? my  old s10 did that too
Offline dexetr30
  • Aloha Mr. Hand!
« Reply #2 on: January 08, 2008, 05:46:31 PM »
That's what I was thinking when I heard the hiss. I won't be able to get to it until the weekend. Hopefully it's an easy fix. I don't feel like fiddling with things to much right now.
flyingbrick
« Reply #3 on: January 08, 2008, 07:51:45 PM »
it is only 8 screws  to get to the heater controls ( I've done my head unit too many times to remember) after that it is just playing with it maybe something is disconnected? anyway good luck with it. and as long as you get heat in the winter it is not that bad.
Offline dexetr30
  • Aloha Mr. Hand!
« Reply #4 on: January 10, 2008, 06:55:00 AM »
Found the problem. The metal insert on the back of the knob broke. I'm going to have to go to the u-pull it this weekend and see if I can find a knob.
