Author Topic: Soon to be installed cruise control  (Read 6366 times)
Re: Soon to be installed cruise control
« Reply #15 on: December 28, 2011, 07:35:05 AM »
those are def the same, how come you didn't use the factory VSS?
What's VSS?  I just follow3d rhe instructions for the install...
« Reply #16 on: December 28, 2011, 08:05:45 AM »
VSS = Vehicle Speed Sensor,you can use the factory sensor, the ECM (PCM) signal or their crank magnetic pickup kit - i assumed you used their pickup kit when you mentioned reusing the sensor.
« Reply #17 on: January 03, 2012, 07:20:07 AM »
No, I used the PCM...  What I mean is that I dont need to take out everything that is wired (including the keypad) because the connection seems to be the same (and since it is the same manufacturer, it probably IS the same).
reddogg
« Reply #18 on: January 03, 2012, 07:28:49 AM »
I installed cruise on my yj a couple of yrs ago. It works great, haven't had any problems with it. It's a CCS 100 by audiovox.
« Last Edit: January 03, 2012, 07:30:12 AM by reddogg »
