Author Topic: Racks?  (Read 4201 times)
Tsd
Re: Racks?
« Reply #15 on: July 10, 2008, 08:44:08 AM »
It is the 52*60, i also bought auxiliary lights mountings but they havenīt arrived yet. Iīm glad you liked it  :beers:
Tsd
Offline smashcoast
Re: Racks?
« Reply #16 on: July 10, 2008, 11:12:09 PM »
How did the drilling go? It goes above the the lights right? How hard was it to drill into the tub?
Tsd
Re: Racks?
« Reply #17 on: July 11, 2008, 08:42:33 AM »
It wasn't hard to do, you just put the rear mount plates and mark the place where you're going to drill. You will have to remember to remove the carpet on the inside of the jeep or you will drill through it and probably set it on fire.
One thing that the write up ant 4x4xplor says and the manual doesn't is that it is a hundred times more easy to install if you remove any top that you have on the jeep, especially when installing the basket.
Hope it helps!
Tsd
Tsd
Re: Racks?
« Reply #18 on: July 15, 2008, 04:19:31 PM »
smashcoast,
After installng the congo cage i had two small solid tubes (didn't appear on the manual) as left overs.  I contacted kargomaster and ii got their reply today:
Thomas
The two rods that you have are used to help hold the rack in the up position
so that you can add or remove the soft top for the Jeep. They are not part
of the install steps.
Thank you,
Marscelles A. Ramirez
-----Original Message-----
Sent: Monday, July 07, 2008 7:44 PM
To: info@kargomaster.com
Subject: Contact Us Form Submission
A visitor to the KargoMaster website has submitted a "Contact Us" form.
Email:
Company Name:
Address:
City: Santiago, State: , ZIP:
Phone Number: , Fax Number:
Referred By: Truck Accessory Retailer
Comments: I live in Santiago, Chile and I bought a congo cage through
quadratec for my '99 TJ. There are 2 small, solid tubes that donīt appear
on the manual and i canīt find a use for them. Thanks in advance.
I donīt have a soft top, so i will guess that what the guy means is that the tubes are used to put up or down the top without tilting the cage completely back. I think you temporary insert them in the holes left by the front bolts (the big ones that attach the cage to the jeep) when they are removed.
Hope it helps!
