Author Topic: TJ Problems. Bogging, Bucking, and High Idle.  (Read 4686 times)
Offline lax22
Re: TJ Problems. Bogging, Bucking, and High Idle.
« Reply #15 on: May 19, 2008, 05:33:43 AM »
The Idle Air Control sensor could be bad or just clogged up with carbon. When i changed my TPS I took everything out and cleaned all the carbon with carbon cleaner so i am not sure if that helped things but its worth a try.
smokey stover
« Reply #16 on: May 19, 2008, 02:24:18 PM »
thanks lax22, i was thinking that would be my next try, i just can't believe that my o2"s would die that quick!!!!
again thanks!!!
Smokey
Offline lax22
« Reply #17 on: July 18, 2008, 12:05:38 PM »
Well teh jeep has been running pretty good since the new TPS sensor untill yesterday. I was driving and it bucked and started acting like its old self again  :brick: It even threw a code and when i scanned it it was saying that the TPS was bad. Its not even a 2 months old!!!! I dont know where to go from here is there anything else i could check?
