Author Topic: 2.5 neeeewb  (Read 4539 times)
acousticrawk
Re: 2.5 neeeewb
« Reply #15 on: July 30, 2008, 09:27:56 AM »
'91-'04 throttle body will work, you'll need to cap the vacuum port for the MAP sensor if it's a '96+ throttle body.
I have 62mm performance throttle bodies available if interested, 7mm larger than the 4.0L and no taper beneath the throttle plate = quicker throttle response.
For my '95 YJ I used injectors from a mid '90s Ford Crown Victoria v8, well I used half of them.
how much for one of those throttle bodies shipped to 45503? are you injectors 19lb'ers?
thanks!!
