Author Topic: TJ flares  (Read 2706 times)
95yjman
TJ flares
« on: August 09, 2008, 01:59:11 PM »
I picked up a set of TJ flares for my YJ.  How hard is it to put these on? Anybody know of any write ups on the net for these? I'm gonna have to cut the body a little bit aren't I?  Also is there any kind of polish I can get to shine them up some and maybe get rid of some scratchs?
Re: TJ flares
« Reply #1 on: August 09, 2008, 06:26:38 PM »
Here ya' go.......  :weee:
TJ flare writeup on 4x4 Wire
Re: TJ flares
« Reply #2 on: August 10, 2008, 02:58:38 AM »
They're pretty easy to install.  I covered the fenders with masking tape, then used a couple clamps to hold the flares in place on the fenders.  Then trace the flare opening and cut just above that line.
For the rear most part of the rear flares, cut right up to the inner fender support without cutting into it.  This will put the front of the flare almost flush with the inner fenderwell.
For the front flares, the cut line at the back of the flare will be almost flush with the inner fenderwell.
I used a jigsaw to cut mine.
blacknblue
Re: TJ flares
« Reply #3 on: August 10, 2008, 08:44:03 AM »
I use Mother's "Back to Black" on my tj flares.  It wont help scratches,  but helps bring out the color and shine evenly.
rroadkilll
Re: TJ flares
« Reply #4 on: August 10, 2008, 04:03:10 PM »
X2
Re: TJ flares
« Reply #5 on: August 10, 2008, 08:03:27 PM »
I took them off the Jeep, sanded them with fine brilo, wiped them down with acetone and then sprayed them with the Krylon made to adhear to platic in a matte finish.  Looked great ad they have held up for 3 years now.
Offline SKI BOY
Re: TJ flares
« Reply #6 on: August 11, 2008, 02:27:05 PM »
[quote author=95yjman link=topic=5076.msg38926#msg38926 date=1218311951]
[/quote]
  "FOREVER BLACK" is also a very good product. Find it on ebay @ about $15.00
Ski Boy
Re: TJ flares
« Reply #7 on: August 12, 2008, 09:50:14 AM »
Best thing I've used to bring back the finish in flares is a heat gun. Start far away, and apply heat evenly, and they will look great.
Re: TJ flares
« Reply #8 on: August 13, 2008, 01:49:05 PM »
i just may have to try that one...  First time I hear about this trick!
