Author Topic: Looking for opinions and advice  (Read 4689 times)
Re: Looking for opinions and advice
« Reply #15 on: August 14, 2008, 07:51:52 AM »
Not true on the TJ.  Front drive shaft spins all the time so unless you remove it you got to regear both axles.
Doesn't matter, you can still run two different ratios with the 231 transfer case as long as you don't engage 4wd.
« Reply #16 on: August 14, 2008, 08:06:52 AM »
Good to know I guess :eek:  Sounds like disaster waiting to happen though.
enginethatcould
« Reply #17 on: August 14, 2008, 08:08:50 AM »
Not as long as I stay out of 4wd :smile:
« Reply #18 on: August 14, 2008, 08:31:55 AM »
Good luck, I'd just save up and do both at th same time :puzzled:
enginethatcould
« Reply #19 on: August 14, 2008, 08:44:38 AM »
Thanks. I might do both and just sale the axles w/gears after I swap axles.
