Author Topic: Dana 35 problem  (Read 1252 times)
CliffB
Dana 35 problem
« on: December 14, 2008, 04:47:12 PM »
My 97 Tj rear axle started leaking from the pinion seal. After futher investigation, I found out the pinion bearing is worn out.
My question is, after everything I've read about the Dana 35 being very weak, I wonder if I should fix this rear end or get a better one. I can get the bearings and seal for around $50. from Quadratec. I can replace the bearings myself. Just feeling lazy too.
Re: Dana 35 problem
« Reply #1 on: December 14, 2008, 05:31:56 PM »
Boils down to your time, skills, and money.  The Ford 8.8 is a great option, buy the axle and a $300 bracket kit and assemble.
DodgeMudder
Re: Dana 35 problem
« Reply #2 on: December 16, 2008, 08:02:02 AM »
the first and biggest question is what size tires do you have now, what size tires do you plan to run in the future and how soon do you plan to upgrade?  If your 33's or less and plan to stay there, I would keep the 35 and just fix the bearing, why put a boat anchor under the back of your Jeep if you don't need it.  If your looking at running 35's or bigger tires in the next year or less then upgrade to a bigger axle.
