Author Topic: Alternator Upgrade for Elect Fan Conversion  (Read 2911 times)
bigbelman2009
Re: Alternator Upgrade for Elect Fan Conversion
« Reply #15 on: January 02, 2009, 09:13:07 PM »
i have a bunch of speakers and lights on my jeep and i was wondering if putting a bigger alternator on would mess anything up if it was too big, because i can get a 140 amp that will work with it but i don't wanna fry anything.
Compstall
« Reply #16 on: January 02, 2009, 10:42:54 PM »
That's what the voltage regulator on the alternator is for.  You ain't gonna hurt anything; the system is only going to take what it needs from the alternator.
« Reply #17 on: January 05, 2009, 09:01:19 AM »
Exactly.  You just got to remember 3 things: (1) you need to make as many amps as you consume (at least!), especially while idling (otherwise, you will drain the battery), (2) that the closer you get to an alternator's capacity (meaning if you are pulling close to what the alternator is producing), the alternator becomes hotter and thus looses efficiency, and (3), the more current draw you put on the alternator, the more horsepower the engine will need to divert from the wheels to the alternator to drive it.  If the alternator is under used, there is no problem, as the voltage will remain steady (should be at about 13.5~14V).
