Author Topic: Loose torque converter bolts?  (Read 6079 times)
jwalls4x4
« on: January 02, 2009, 07:27:51 PM »
Lately I have been hearing some knocking noises coming from my trany that quieten when I put her in gear.  I took it to a mechanic and he said my torque converter bolts were loose  ???  Has anyone had this happen?  He said it might be an easy fix if I have a dust cover to get to it with....Do 3 spd ATs have this?
lanulos89
Re: Loose torque converter bolts?
« Reply #1 on: January 02, 2009, 07:40:02 PM »
yea they do if i remember correctly , get under your jeep and look for a shield in the front of the trans, and pop that out, you may need to take the starter out b/c it acts as a shim as well.  you might be able to do all the work from the starter hole itself,  pop the screws out loc-tite em and tighten em back up..  as for it happening to me never, nd i beat the shit outta my jeep but anything is possible and ive learned that.
p.s.  those starter bolt ond the autos suck dont strip the heads
« Reply #2 on: January 03, 2009, 07:49:56 PM »
I've heard of the flex plate cracking and making noises... and as mentioned above don't mess up the starter bolts.. they suck. (inverse torques)
jwalls4x4
« Reply #3 on: January 13, 2009, 04:54:43 PM »
Thanks guys, It was the torque converter bolts loose.  All of them.  Thankfully, it was caught before the flex plate was damaged :eek: Only cost $40.
« Reply #4 on: January 15, 2009, 07:47:44 AM »
Seen this twice on other's rigs, both thought it was a motor knock.
« Reply #5 on: November 26, 2009, 03:35:34 AM »
If it has the funny tunk tunk sound it does, not all that unncommon.
You want to check that like now. When it stays loose for awhile it will beat out/slot the holes in the flex plate and then you might as well change that also and that is a whole lot more work
« Reply #6 on: November 26, 2009, 07:01:55 AM »
 Holidaymakers come here to wow power leveling make use of the longest
beach in wow power leveling the whole of Menorca. Even
though it is a world of warcraft gold tremendously popular
placeto enjoy the sun 重庆二手交易 and sea, its sheer size (at over two and a
half kilometres in length) means that, gold in wow with a
little walking you can find wow gold eu an area of beach to
call wow gold chea your own.Where you have sand, you will often
find wow cheap gold sandstone.
:eek:
loose converter bolts you mean?
« Reply #7 on: November 26, 2009, 09:02:18 AM »
Happens a lot with AW4's - loose bolts.  Which then leads to the flexplate cracking.
« Reply #8 on: November 26, 2009, 09:26:50 AM »
Insert Quote
Quote from: yoyohh on Today at 12:12:30 AM
:eek:
if you wonder what's with this post it was someone posting ads
