Author Topic: 31 MTs with stock gearing  (Read 25814 times)
JeffsJeep
Re: 31 MTs with stock gearing
« Reply #60 on: March 05, 2009, 01:06:22 PM »
And wheels with more offset...
Whats offset mean?  Sorry I'm kinda new to this Jeep thing...
« Reply #61 on: March 05, 2009, 01:42:09 PM »
Where the mounting surface is in relation to the center of the wheel.
Read this..... https://www.rsracing.com/tech-wheel.html
« Last Edit: March 05, 2009, 01:43:23 PM by Jesse-James »
  • Poseur Extraordinaire®
« Reply #62 on: March 05, 2009, 04:24:47 PM »
Can it break of course can a Dana 60 break you bet.
It better not....... :eek:
« Reply #63 on: March 05, 2009, 04:30:47 PM »
Remember Tinknocker that was with us at The Cliffs? I watched him bust a 60 shaft into 4 pcs with his 4 banger, it happens.
« Reply #64 on: March 05, 2009, 04:37:26 PM »
Well...if someone was going to break one, it would be him.....and I know you are not comparing my wheeling to his... :roflol:
« Reply #65 on: March 05, 2009, 05:47:25 PM »
Kinda hard to break something wheeling the Michigan highways Moz :dance:
« Reply #66 on: March 05, 2009, 05:52:21 PM »
True...and probably didn't have a chance a The Cliffs....this guy had a hardcore 4-banger though...
<a href="http://www.youtube.com/v/A8XNbvxvWJE&amp;hl=en&amp;fs=1" target="_blank" rel="noopener noreferrer" class="bbc_link bbc_flash_disabled new_win">http://www.youtube.com/v/A8XNbvxvWJE&amp;hl=en&amp;fs=1</a>
st.chevrolet
« Reply #67 on: March 05, 2009, 08:05:07 PM »
remember that most people dont buy a new Dana 60 when they add them as a upgrade, due to cost most buy used older Dana 60's. I found My Dana 60 used for 50 bucks and in not bad shape, needless to say near to impossible to duplicate that deal haha.
With older axles the metal in the axle shaft can sometime become weakened from time and hard use, now i completely rebuilt my 60 not everyone does that due to cost (way over 1000 bucks) they run em as found. This is in most cases why big axles break in situations that one would think they cant break.
« Reply #68 on: March 05, 2009, 08:17:53 PM »
Actually it's usually when the driver doesn't let up when the rig starts hopping. All the weight comes down on one tire with full throttle and when it get traction *snap*
« Reply #69 on: March 05, 2009, 08:33:10 PM »
That or kind of get a wheel caught and then romp on it to get it to move seen an axlle snap like that with a good lowrange you can put an awfull lot of torque to the wheels
st.chevrolet
« Reply #70 on: March 05, 2009, 08:42:17 PM »
Even with that situation there is no way that a rebuilt Dana 60 would have any problems with a 4banger even running large tires, unless it has some dam big gear reduction or huge forced induction. The T-case would fly apart long before the Dana 60 would. I run a Dana 60 front in my 1 ton Chevy with 37x13.5-R17's, it is fully locked with 5.13 gears, and I have tried to break it with a V8 with no luck at all even with the above described situation.
« Reply #71 on: March 05, 2009, 09:08:03 PM »
Seen it with my own eyes..... Hard to break, yes. Impossible, no.
And it was not because the shafts were "old" both rear tires caught air from hopping and the right rear came down between two rocks and was forced to stop with full throttle still applied.
Carb'd 2.5L, AX15, 207 case, 5.13 gears
Play this vid, at 5:00 he's doing the same thing. No breakage this time cause the wheel didn't get trapped like it did when it broke, but you get the idea.
http://www.ecoyne.com/getvid.php?id=22
« Last Edit: March 05, 2009, 09:09:08 PM by Jesse-James »
st.chevrolet
« Reply #72 on: March 05, 2009, 09:25:30 PM »
Thus why a 14bolt makes a better rear lol
I didn't know we were talking about rear axles but there are light duty Dana 60 rears that are out there to, the fronts tent to be bigger unless they are really old with the stepped down axle shafts. In kinda thinking that the 60 was one of the smaller axle shaft ones out there, more likely to have them break rather then the 35 spline rear Dana 60s.
« Reply #73 on: March 05, 2009, 09:50:14 PM »
That is what I'm affraid of each time I see a undercut. With over 200:1 and 37's the 30 spline shafts in the rear can snap pretty easy(D44). Even though they are cryo'ed cromo's.
Like others have said, bouncing is another way to snap stuff. Seems like it's the 3rd bounce then KA-BAM!
