Author Topic: Ford Design III Injector install  (Read 3564 times)
jeep55
« on: March 20, 2009, 09:04:09 AM »
So far I'm not thrilled, I might have felt alitte something. I put them in ,a cleaned set, new o-rings etc.  Am I expecting to much? I already have the 4.0 throttle body, a TB spacer, cold air, MSD ignision and MSD coil, copper plugs with a .45 gap, electric cooling fan.
What else for a cheap buck, shade tree mechanic, on a 2.5L monster.
My next little project is to open up the opening in the intake to match the bigger TB and spacer. I do have 4 left, I bought 8, they are " You are looking at a beautiful set of Ford 19lb. Injectors. They are design 3 and will be a great upgrade for F-series trucks, Mustangs, Thunderbirds, and Bmw's. These are the 4-hole squirter type so they provide better fuel atomization so that means BETTER IDLE AND MORE POWER." I might sell the other 4 for $30.00 shipped east coast, $35.00 West Coast.
This was not an advertisement. Looking for perfomance help.
Thanks in advance, and keep up with my posts , I will have updates on my (Jeep's) upgrades, Glenn
Mr_Random
Re: Ford Design III Injector install
« Reply #1 on: March 20, 2009, 02:10:53 PM »
With a system kept fresh and upgraded such as yours, I expect you've used injector cleaners and such... therefore you're less likely to notice as much of a difference. Had any time to compare gas mileage? It could have gotten better without adding much power. I've read that the biggest difference is idle being smoothed out, especially with good mods like yours.
I might be interested in your remaining injectors, I'll let you know within a week.
« Reply #2 on: March 20, 2009, 03:35:43 PM »
Have you reset the computer lately?
jeep55
« Reply #3 on: March 20, 2009, 05:19:07 PM »
Your right,  I always use Lucas Injector Cleaner. I just did them and have not had a chance to check mileage yet. I guess that every little thing helps. I does run pretty good compared to what people usually say about 4 bangers. I like mine. Let me know about the extra 4 injectors.
Thanks, Glenn
jeep55
« Reply #4 on: March 20, 2009, 05:20:42 PM »
No I have not, do I just need to disconnect battery for awhile?
That might adjust to the new specs?
Thanks, Glenn
Mr_Random
« Reply #5 on: March 20, 2009, 10:36:53 PM »
Thanks, Glenn
Ground the positive cable to the negative terminal for fourty seconds, it'll erase the capacitive memory in the ECU fully, disconnecting it alone may not do the job.
and I'll let you know...
« Reply #6 on: March 21, 2009, 09:40:04 AM »
Resetting the 'puter helps ensure that it has properly adjusted to any new changes.  The ECm learns new operating parameters over the next 50 warm-up cycles.
DodgeMudder
« Reply #7 on: March 23, 2009, 07:56:04 AM »
If he doesn't take them I'm interested.
hyp7
« Reply #8 on: March 23, 2009, 04:19:50 PM »
payment sent on injectors
thanks Hyp7
jeep55
« Reply #9 on: March 24, 2009, 05:58:08 AM »
thanks Hyp7
Got it, Thanks
Glenn
drunkencityworker
« Reply #10 on: March 24, 2009, 11:13:08 AM »
i threw a few injectors  in toolbox when in jnkyrd last. yellow like those piced in other threads out of 4.6 crown vic. I am going to wait till i get the coil cap n wires so i can over gap before i put them in is this the correct way to go about it? I already did the 4.0 TB and i likey thanks for all the tips. didnt mean to hijack thread but theres too many of these injector threads as is
miwoodar
« Reply #11 on: March 30, 2009, 10:32:28 AM »
Any updates?  I just swapped my injectors yesterday and did the 4.0 throttle body while I was under the hood.  I couldn't really tell a difference but I haven't had it in the mountains yet.  The first climb out of Denver on I70 has always required quite a bit of flogging to maintain 60mph...I'm thinking this will be a good test.  Maybe next weekend.
jeep55
« Reply #12 on: April 17, 2009, 07:46:14 PM »
Well, I have had the injectors installed now for awhile. I reset the computer and drove for a week or so. I now can really feel the difference in the top end power. I can actually speed up in 4th gear. Anyways, I like the change.
Glenn
Offline TahoeYJ
« Reply #13 on: April 18, 2009, 02:30:04 PM »
Glenn
Add a hotter coil if you haven't already done so, and you'll see even more improvement  :hump:
