Author Topic: Finally got around to buying some 31" MTs  (Read 4666 times)
Re: Finally got around to buying some 31" MTs
« Reply #15 on: July 26, 2009, 01:05:19 PM »
There is round ones too but these fit better on that bracket.
  • 4BangerJP.com® Donator
« Reply #16 on: July 26, 2009, 01:15:59 PM »
I see.  Yeah, I'll do something like that or put it on top of the fenders.  Thanks for going to the trouble of snapping the photo  :thumb:
« Last Edit: July 26, 2009, 01:16:49 PM by chrisfranklin »
« Reply #17 on: July 27, 2009, 10:17:58 AM »
Well placed market lights underneath your fender... What brand are those and how much is the price?
They are made by Trucklite. I got them at Napa. I think for the light, grommet,pigtail is around $6-7 ea. But it's been awhile. These are not LED,just a standard bulb.
« Reply #18 on: July 27, 2009, 11:47:41 AM »
Would be cool if you could put a circuit somehow to turn them on all the time; that way, they would also sort of work as rock lights!
  • Poseur Extraordinaire®
« Reply #19 on: July 28, 2009, 11:17:16 AM »
The lights you can buy there are usually only 2-wire trailer lights and will not give you the turn signal function.
I bought mine from here....
http://www.vehiclelight.com/index.html
Mounted them on the hood for simple wiring, good visibility...going for that whole "current European standard" look.....and now I can't find the pic....
« Reply #20 on: July 28, 2009, 11:40:26 AM »
Mine work as turn signals too. They are a 2 wire but they work for both marker and turn signal.
I have seen the 2 inch round ones mounted on the side of the hood, near the hood latch. That looks good too.
« Reply #21 on: July 28, 2009, 12:22:35 PM »
yep...that's because the light itself acts as the ground (like the stock units)...I'm always in LED mode....
