Author Topic: Cleaning the MAP Sensor  (Read 2079 times)
  • 4BangerJP.comŪ Donator
« on: July 06, 2009, 07:12:06 PM »
I thought the MAP sensor was sealed.  But apparently you can get inside and clean it somehow? I guess I'll just pull mine off and see what I can do with it; 165k so it could probably use a going over.  If you guys have done this before and you know I am in danger of busting something trying to get inside the MAP sensor, plz let me know  :bandit:
Re: Cleaning the MAP Sensor
« Reply #1 on: July 06, 2009, 07:21:30 PM »
do you have a spare? you know why i'm asking  :biggrin:
« Reply #2 on: July 06, 2009, 11:14:17 PM »
Nobody has ever done this?  Ahh Man! :lol:
« Reply #3 on: July 06, 2009, 11:22:49 PM »
there's nothing to clean really - there is no air going in or out the MAP sensor, it is only pressure difference (vacuum) but no air movement (or air circulating to be more specific) so unless it was unplugged (the hose off the nipple) there shouldn't be any dirt in it. Just wondering, why do you want to clean it?
« Reply #4 on: July 07, 2009, 09:29:37 AM »
I was looking at the post in the work bench section on the engine lean code.
« Reply #5 on: July 07, 2009, 10:20:13 AM »
he probably clean the connector pins on both ends to make sure there is no loss or no connection there.
« Reply #6 on: July 07, 2009, 11:29:49 AM »
Yep.
« Reply #7 on: July 07, 2009, 10:47:52 PM »
Oh, so i guess any electrical connection cleaner will do the trick probably.
