Author Topic: 98 Wrangler Gear upgrade  (Read 1904 times)
kawstxf15
« on: July 19, 2009, 08:16:08 PM »
My 98 Wrangler  (2.5L) has 33 x 12 1/2 tires and it is lugging the motor.  What gears do you recommend and who do you recommend for parts & service.  Thanks :dance:
BarneyJeep
Re: 98 Wrangler Gear upgrade
« Reply #1 on: July 19, 2009, 08:26:09 PM »
4.88's
« Reply #2 on: July 19, 2009, 10:20:36 PM »
yep 4.88's at least.  I've got 33X10.50's and 4.88's. also got a D44 in the rear and a D44 waiting to go in the front so I can go 5.38.  The 4.88's are ok (I've got an auto) but plan on 35's.  The only time they aren't great is when I'm trying to go up a muddy hill and need some wheel speed.  4H isn't enough and 4L is too slow.
« Reply #3 on: July 20, 2009, 09:18:17 AM »
I agree; AT LEAST 4.88.  I have 33's and 4.88, and I need to downshift to 4th if there is a head wind or if I go up an overpass.  I really liked the performance of the 4.88 and the 31's I had before, so I would say 5.13 (IIRC that is the next step for a D44) would be ideal for 33's, but you can only go up to 4.88 with the stock axles.
Castr8r
« Reply #4 on: July 20, 2009, 03:23:30 PM »
4.88's for sure!  I couldn't get out of fourth gear on the hiway and lo-lo was too fast for some of my crawling.  After the 4.88's were installed, I can use fifth gear to run 70 mph on the interstate and crawling is better, much better.
« Reply #5 on: July 20, 2009, 04:02:51 PM »
Why not use 4L and second gear?  4L and third gear is pretty close to 4H in first.
« Reply #6 on: July 20, 2009, 04:18:16 PM »
He has a terra low which makes for a big step between high and low range.
Sand and mud hills ask for power and a lot of momentum which is not easy with a 4 banger
« Reply #7 on: July 20, 2009, 04:47:58 PM »
Then he has 2nd and 3rd to experiment with (with a 4:1, 4L and 4th gear is very close to 4H in first).  But I agree, the 4banger is not the best for those terrains, sometimes a low gear will give you acceleration but not a high enough final speed (engine revving too much) and a higher gear will not get you to the needed speed due to slow acceleration on the typically short approach.  I´ve noticed this on sand hills where the 6 cyl Jeeps tend to do much better.
« Reply #8 on: July 20, 2009, 05:26:01 PM »
Yup sand takes a higher gear and grunt to keep er going
