Author Topic: diff cover clearance  (Read 5928 times)
Re: diff cover clearance
« Reply #15 on: August 17, 2009, 05:12:48 PM »
It can get pretty tight on a TJ especially when you try to push the axle back.
For U joint protection use a Ninth degree. AEV diff slider just make sure it doesn't gouge the drive shaft. With enough lift it stops being a problem because the pinion gets turned up quite a way with a cv shaft. I have scraped my front straps which has since been solved with a high pinion axle the rear has never been scratched even though it has belly flopped on rocks quite a few times
drunkencityworker
« Reply #16 on: August 17, 2009, 09:35:07 PM »
so which of the cover offers the most clearance. the sites talk bout thickness of cover and ring section. but not how far out it hangs. i know ruff stuff is one of the bigger ones
drunkencityworker
« Reply #17 on: August 17, 2009, 09:39:59 PM »
personnelly i am going to hold off on pinion skids. gas tank skid and diff cover are taking priority till it becomes an issue
« Reply #18 on: August 17, 2009, 10:46:29 PM »
I have yet to see one on an 8.8 anyway. Sure would like to do something though.
« Reply #19 on: August 18, 2009, 05:19:33 AM »
Just built one out of 3/16 steel plate it's not all that hard and when it overla[s the edge of the diff cover you can pretty much stick with the stock one since it will protect it from peeling open on rocks.
drunkencityworker
« Reply #20 on: August 18, 2009, 05:56:43 AM »
could you post some pics up?
« Reply #21 on: August 18, 2009, 03:06:36 PM »
Mine is on a dana44 but you get the idea
http://4bangerjp.com/forums/index.php/topic,4695.0.html
You can combine it with the ring that JJ has over his diff cover make the front longer to protect the pinion Yoke and you are golden
