Author Topic: how will a 2.5 do with 35s????  (Read 7364 times)
Re: how will a 2.5 do with 35s????
« Reply #15 on: August 22, 2009, 08:19:07 AM »
one more thing to check out is does it have sye or stock slip yoke. if sye then thats a good little chunk of $ you dont have to worry about. i did 8.8 swap for about 600. my sye was another 300.
+ the driveshaft which was another $2-300 probably
drunkencityworker
« Reply #16 on: August 22, 2009, 05:53:39 PM »
personnely i got a used sye for 160. and had a $20 junkyard xj shaft shortened for $74. dont let catalog prices scare you. there is a bunch of aftermarket stuff out there for the cheap.
drunkencityworker
« Reply #17 on: August 22, 2009, 05:58:07 PM »
I did have to bite bullet on somethings new tho. SS brakelines extenssions and shock mounts and shock mount relocaters. but be patient and watch local boards,ebay,cl. sorry if off topic
« Reply #18 on: August 22, 2009, 08:43:41 PM »
For the extensions, you only need the rear (which is supplied by most lift kits; or at least by RE!), as you can reroute the hard lines to go under the frame and gain enough clearance for a 4" lift...
C.Redbeardd
« Reply #19 on: October 29, 2009, 05:45:17 PM »
I have 35's w/ 5.89 gears. Gets up to 65. Which will do around town, but its about to become a full-time toy, and not a dd. In fact, my tires are almost up and im looking to go a little bigger, maybe 37's?
Bigboyky
« Reply #20 on: October 31, 2009, 02:59:44 PM »
well since someone brought up an older thread I'll post up my experiance..... I ran my little motor with the stock gearing (4:10) for a year with 33's. Then when I put in the lockers and 8.8 I went to 4:88's. I wanted 5:13's or deeper but couldn't with the D30. Anyway with the 4:88's she does just fine I actually use 5th gear again. I can run 70 to 75 down the highway. And wheeling it's great I use 2nd and sometimes even 3rd with no issues. Now to go to 35's I feel I'd be lacking the umph on the road. If I were to do it agian I'd change out the front axle also and go deeper. So that's my 2 cents.... gee thanks now I'm broke.
radark1
« Reply #21 on: November 21, 2009, 11:17:55 AM »
You won't have to worry about getting a speeding ticket....unless you consider rockcrawling in the school playground....when school is in session. LOL.
