Author Topic: Throttle Body Trade  (Read 1573 times)
Offline mrcabinet
Throttle Body Trade
« on: September 09, 2009, 04:20:25 PM »
I messed up and jumped into buying a 4.0 throttle body for my 2.5 before fully researching all the details. I got one for a '91 to '95, when I should have gotten one for a '96+ (with the MAP mount on the TB). Of course, now I can't find one locally, and I'm really anxious to do this swap.
So, if anyone here has a '96+ TB that they'd be willing to trade for the one I have, I'd sweeten the deal and throw in the 19lb. injectors that I won't be using now.
drunkencityworker
Re: Throttle Body Trade
« Reply #1 on: September 09, 2009, 04:28:41 PM »
i used the same one you have. I just plugged it with an extra screw and it works just fine. you should be ok. dont forget to change the other sensor housings from 2.5 to the 4.0
« Reply #2 on: September 09, 2009, 04:35:13 PM »
you could talk to Bounty Hunter and he may let you do a parcel trade for a bored out 4.0l throttle body.. he is a vender so it would probably be worth seeing what he can do for you if you can't find anyone to trade with.
Offline mrcabinet
« Reply #3 on: September 09, 2009, 04:53:53 PM »
No, I need the one WITH the vacuum tube and threaded holes for the MAP to hook up to.
